![]() | Home > Technical > How should SC sound when stopped |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
I can't say mine does this. Do you mean it hunts for a second? Eg, up and down then settles? when off the gas? |
| Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35
When stationery r for eg when u pull up to a junction and pause before pulling out, it hunts slightly, like between 500-750 revs then steadys at constant 500
It does not sound that bad then if it's only a hundred or so. Try some fuel cleaner in a tank of gas. Would not worry to much as the car would come up with a fault code if there was a problem. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
^^ True but TigerDon doesn't say he's had the codes read? Or are all you SC owners in psychic touch with each other? |
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450
mine does that now and then, fault code P0170 Fuel Trim Bank 1. Is in to dealer tomorrow to get checked out. Apparently, there are lots of small problems which can give this error code, mainly air getting sucked in from somewhere. I've had O2 sensors (x4) and Mass Air Flow sensor done, so now its a proper mechanics turn. |
Guys mine isint firing up any codes
| All times are GMT |
