![]() | Home > Technical > Squeal when cornering |
| RainHard Member Since: 07 Sep 2013 Location: Lonehill Posts: 20
The workshop foreman took it for a test drive today - disc need replacing. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Eh? Did he explain how a worn disc can cause a squeal but only when going round a corner?
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
I agree with Paddi its more likely to be a wheel bearing than a brake disc.
You guys are spot on - I did the discs today (they did have 3mm wear). Squeal is still there - I Will change the bearing and see how things go (but that will be next month - bit broke).
| All times are GMT |
