![]() | Home > General > Another NEWBIE |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Welcome to the madhouse |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
Hello mate & welcome |
roscopcoltrane Member Since: 31 May 2013 Location: Scotland Posts: 86 ![]() ![]() |
Welcome chap, there is a thread on build sheets, just do a search |
Welcome along. "for the wife " |
Lloyd Member Since: 01 Oct 2013 Location: Hampshire Posts: 8 ![]() ![]() ![]() |
I will have a look at the catch tonight. On another note when I hit the lock button it sounds the horn, is that normal can I stop/change this?
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Normally happens if something isn't closed properly - bonnet perchance? Either of the boots? |
Yes if something is open - in this case your bonnet thinks it is open (Hood ajar switch). But it isn't the horn it's the "battery backed -up sounder". It's a Land Rover ![]() ![]() |
Cheers fellas I will have a play tonight and let you know the outcome!. |
Lloyd,
Thanks Paddi I will have a look for him.
Sunny boy Member Since: 01 Oct 2013 Location: Notts Posts: 2 ![]() ![]() |
Hi Looking to take the plunge and buy my first rrs, have seen a sweet 2006 black HSE colour coded and fully loaded 2.7tdv6. Have heard loads about the unreliability but the cars look the business so going to go from my V8 Audi S4 to a range, any advice would be much appreciated, what should I watch out for? The one I'm going to see has had 4 previous owners, full service history mostly main dealer then 2 at local specialist BUT the current owner did day it has had a new engine supplied and fitted by land rover at 50k. This was due to injector failure and payed for by the insurance company, it's done 88,000 but the engine has done less as its new. Should I be worried and should I avoid. Current owner has had the car for his wife for 3 years and seams to be a middle class working professional, but I'm always weary buying private.
If it's had the engine replaced, then I'd be smiling. As long as everything works a s it should, then no reason to worry I would say. |
Cheers, I was hoping for better fuel economy than my s4 but, I think it will be worth taking the plunge. Anything else I should look out for? Read so man reviews and its slightly confusing, is it worth getting a warranty? Are these available from main deler on older cars? |
On another note I want to get the belts changed so the questions are
