![]() | Home > Technical > Suspension tolerance question |
MisterAdam Member Since: 03 May 2012 Location: Liverpool, UK Posts: 352 ![]() ![]() ![]() |
I had a simmilar issue when I got the car, noticed one corner was ever so slightly lower than the rest, to the point where nobody else could notice it but it was one of those things that being the owner YOU notice it.
Yeah I only noticed it because I keep looking for things. Paying the price (i.e. diagnostic charge) of being too pedantic now |
Buy your own tool and calibrate it yourself.
Thanks SRE. Looks good but the trouble is if I get it I would want to raise the normal ride height to increase the comfort as much as possible and I don't know what the consequences of that could be |
Maybe go for the full IIDTool, verty handy bit of kit and can read and clear all your faults
Thanks again SRE. The IIDTool looks like a great piece of equipment. However, since it is locked to a certain VIN and I have a feeling I might want to change the car early-mid next year, it seems like something I should buy at that time.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
Sitting down on the o/s/r corner seems to be a common "feature". Mine does it too. It comes back up to something similar to the n/s/r once it's being driven. One thing I've noticed is that it doesn't do the drop on that corner if it's parked in off road mode. That suggests that there might be a bit of wear in the sensor on that corner, although why that corner should wear more than others is beyond me.
Yes, seems to level up fine a few moments after starting even if not being driven although I am not 100% sure. Definitely drives level according to the Mrs. when following me. |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
FWIW this is my understanding.
I think it's more likely to be a bit of crud in the valve block controlling the rear end rather than a leaking airbag.
RRSTDV8 this one?
Yes, that's the thread I mentioned. |
I asked Pete@LandRover whether 13mm was within tolerance and he confirmed the tolerance limit was only 10mm. However, the extended warranty explicitly excludes any adjustments even if they are outside tolerance (checked with Car Care Plan on the phone too).
