Home > Faults & Fixes > Yellow SUSPENSION LIGHT |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
if the car going is up and down ok with any errors at first it seems the pump is ok though people say 60000 miles is when most fail. try a hard reset as youve changed the battery. Reset, touch the two battery terminals together for a minute. if still comes on im afraid it to the garage to get it plugged in. maybe its getting tried and needs replacing. Drive in and out for £450 at a good indy garage. |
Thu Sep 19 2013 7:27am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
@SCdavies
I am sure you mean the battery leads and not the terminals as this would fix more than his suspension Flack |
Thu Sep 19 2013 9:20am |
i stand corrected but im hoping he knew what i meant. |
Thu Sep 19 2013 11:15am |
navtec Member Since: 13 Feb 2013 Location: nottingham Posts: 13 |
So remove the positive and negative from the battery and then touch together for few minutes?
Thu Sep 19 2013 11:06pm |
Yes join both leads together with a socket bar or big screw driver for about 1 min .. Plugging in a PC will not do a hard reset.
Thu Sep 19 2013 11:16pm |
I did replace the battery that i purchased brand new from auto parts store , the original battery is 950 MHA or something like that, but this one is 850. Would that make any impact on the error ? |
Fri Sep 20 2013 11:16am |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
I'd say that your pump needs replacing. If it works initially and then the fault appears, the pump is probably over heating. Once you've stopped and let it cool down, then it works again - for a while, until it overheats again. Same thing has just happened to mine RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sat Sep 21 2013 9:49am |
Is there a repair kit available to bring compressor back to normal instead of replacing the whole unit. |
Sat Sep 21 2013 10:08am |
not that I've come across. RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sat Sep 21 2013 10:14am |
You can buy a new valve kit and piston. £75. Rimmer bros and bayer. |
Sat Sep 21 2013 4:19pm |
Yes there is a kit to overhaul the pump but the problem is that when you try to strip it down to replace the parts you end up snapping and stripping the threads so end up buying a new pump..
Sat Sep 21 2013 4:20pm |
Before i buy compressor and replace it, i think better to do a diagnostic check just in case something else flagging up the error. I may even also purchase a diagnostic machine for future use. Any decent machines out there that can do most of the cars in the market, not just basic engine read but many other resets inc checking suspension faults etc. |
Mon Sep 23 2013 2:00pm |
I use a hawk eye tool. Very useful and has saved me money. |
Mon Sep 23 2013 8:33pm |
