| RRSPORT.CO.UK | ||
|  | Home > Technical > Upper Tailgate Unlocking on Start |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    |
 Jumped in the RRS this morning and started and there was a rattle in the back. Drove off and then noticed the tailgate open message was on the display. I arrived at the shops car park and closed the upper tailgate and locked the car.
|  Tue Sep 17 2013 11:34am |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | Hopefully someone else can clarify this but sure I read on here that corroded tailgate switch caused this issue - might be a worth doing a search  | ||
|  Tue Sep 17 2013 11:37am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | You don't say which MY you have but if it is pre 2010.......have you perhaps accidentally programmed the third button on the fob to open the upper tailgate? If so, it is quite easy to press the third button as you start the car (done it myself). 2008 MY Java Black TDV8 HSE
|  Tue Sep 17 2013 12:58pm |
 Thanks - I will look into it. So are we talking the sensor that tells the system if the door is open or closed or the mechanism that actually locks and unlocks the door - also if it is corrosion I do not understand why the issue dows not show up until after the engine is started and not when power is first applied to the system via the ignition switch. But something to look at thanks. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior | ||
|  Wed Sep 18 2013 2:59am |
 Thanks - thought that as well as the key I was using does open the tailgate but my spare key turns the lights on and the issue happens with both keys. Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior | ||
|  Wed Sep 18 2013 3:01am |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | From reading others comments I believe it is the switch under the rubber that you press to release the top tailgate  | ||
|  Wed Sep 18 2013 7:37am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | I have had a good look at this today - the actual switch seems OK and even with the switch disconnected the actual lock disconnects up to 60 secs after engine start.  There is an electrical pulse coming through the system unlocking the upper tailgate.
|  Wed Sep 18 2013 8:46am |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | Have you tried pm to Bruno2 - he may be able to advise how he fixed it  | ||
|  Wed Sep 18 2013 8:50am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | No - but on your advice I now have.
|  Wed Sep 18 2013 8:59am |
| Bruno2 Member Since: 23 Mar 2013 Location: Caithness Posts: 2      | Hi
|  Wed Sep 18 2013 7:05pm |
| Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522      | Hi- I'm new here! I've got exactly this problem- did you ever find the snag? I've got 6 months warranty do keen to get it fixed!
|  Wed Sep 18 2013 10:36pm |
 Thanks As it is a sealed unit - any ideas how the water got in? Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior | ||
|  Thu Sep 19 2013 1:48am |
| Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522      | Apologies- I thought this was an old thread!
|  Thu Sep 19 2013 7:09am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | Any one with any ideas other than the switch - I checked it today and there is no corrosion inside it (as said when disconnected the issue is still there).  The thinking is that maybe there is an intermittent short in the cables that go to the switch - maybe a fault in the Body Control Unit.
|  Fri Sep 20 2013 9:02am |
| Posting Rules
