Home > Maintenance & Modifications > Front Brake Disc Removal - Help
Scottydog
2006 Range Rover Sport TDV6 HSE Java Black
In middle of repalcing the front hub, but struggling to get brake disc off. Tried some gentle persuasion with hammer on edge of disc, but not budging. What next? Heat?
Thanks in advance.
Scott
Post #394872 Fri Sep 13 2013 12:35pm
Bodsy
Site Sponsor
You've removed the Torx bolt I assume?
Have you followed the brake bible? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #394876 Fri Sep 13 2013 12:55pm
Scottydog
Yeah, disc bolt removed! Will have a look at the bible.
Scott
Post #394886 Fri Sep 13 2013 1:40pm
Disco_Mikey
Bigger hammer and hit it harder Thumbs Up
Post #394947 Fri Sep 13 2013 6:40pm
Scottydog
Quick update. Disc stil not coming off so have taken off the whole assembly and going to garage to see if it can be pressed off.
Next issue I have is changing the lower arm. Followed the guide and now got to last bolt to come off and the bush is seized to nut, so next question is where and how do I cut? Any suggestions?
Scott
Post #394971 Fri Sep 13 2013 9:46pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
I used a fly wheel removal tool.
Post #395007 Sat Sep 14 2013 4:37pm
Haybale
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Mine was seized on the other week and no end of "persuasion" would shift it. Quick squirt of WD40 and it popped straight off with the next tap. Just remeber to to use brake cleaner on the disk before putting it back on again Very Happy
Post #395737 Sun Sep 22 2013 8:49am
