Home > Maintenance & Modifications > Cheap fix for GPS Aerial. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
I have had a few gps antennas failed lately in the shark fin aerial and was looking around for a cheaper alternative even the breaker yards want £50.00 for a second hand one, so this is my fix for £6.49p.
Thu Sep 12 2013 10:07am |
Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42 |
That's my task for the weekend then. Thank you for a superb guide. 2011 Evoque Si4 Dynamic plus lux
Thu Sep 12 2013 5:25pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Hi Flack I have problem with my satnav. you cannot program route on postcode as only numbers appear on screen. top corner of screen shows GPS with red cross through it, so I take it no GPS, but when driving pointer shows you moving so I thought this would be controlled by GPS??
Sat Mar 01 2014 4:39pm |
Yes its your Gps aerial that has failed, the pointer will still move but not track on the map or follow a road because it does not know where it is.
Sat Mar 01 2014 5:52pm |
Many thanks Flack will order one and give it a try.
Sat Mar 01 2014 5:58pm |
How good was your post flack Done it today, Idrilled 13.5 mm hole and kept cable long so no need to cut and join cable. The hardest bit was getting the plate above the head lining back on with the 2 10m mm nuts other than that all went good.
Mon Apr 21 2014 3:23pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1741 |
Check which country you have selected. I think it defaults to Belgium!! 2023 P440e SE Dynamic on order -cancelled
Mon Apr 21 2014 3:41pm |
Thanks jimbg. Read the posts played with screen and found on Belgium reset all normal now.
Mon Apr 21 2014 3:46pm |
Yes its a good cheap fix..
Mon Apr 21 2014 5:12pm |
Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46 |
Sun Jan 04 2015 4:22pm |
If you get the part all the work is done above rear luggage area in the roof space. Remove aerial solder in new part and replace. do it in the dry as water would come through holes in roof. It is a bit awkward locating nuts but I am 22 stone and not so agile but done it ok.
Sun Jan 04 2015 4:36pm |
So we just get a new aerial, cut the wire from it and solder the old wire onto the new aerial circuit board? So removing any casing from the new aerial we just want a new board basically?
Sun Jan 04 2015 7:58pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Well done fantastic mod. |
Sun Jan 04 2015 8:17pm |
I fitted printed circuit board into where old one was removed, drilled a hole large enough for connector to go through so didn't cut wire. Secured in with hot glue gun. I think (a while since I done repair).
Sun Jan 04 2015 8:20pm |
