Home > Technical > TDV6 is replacement alternator a DIY job?
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
Battery warning light came on a little while ago, having looked through the forum, seems to be a lot about changing an alternator on TDV8 but not a lot on a TDV6 is it a DIY job or do I have to put it into LR to be fixed About to get into a sport
Post #394244 Sat Sep 07 2013 8:15pm
aljo
If you check out the disco3 forum you will find plenty of information on the TDV6 and yes its an easy job Thumbs Up
Post #394245 Sat Sep 07 2013 8:18pm
Simon58
thanks aljo for the advice, I have had a look on the forum, I will take a look at the car in the morning, hope its the right thing i am changing! About to get into a sport
Post #394248 Sat Sep 07 2013 8:45pm
Disco_Mikey
It is still a DIY job, but if you have ARC/Dynamic Response, it can be quite awkward to get the 2 bottom bolts out of the alternator
If no ARC is fitted, then its a half hour job Thumbs Up
Post #394252 Sat Sep 07 2013 9:33pm
Simon58
thanks DM my sport is an 58 HSE not sure if it has it of not About to get into a sport
Post #394253 Sat Sep 07 2013 9:35pm
Simon58
had a look this morning, have taken the air pipe out of the way, and the top half of the fan cover, had another look and have now stopped, next move would be to take off the fan, not sure how I remove the bottom half of the fan cowling as this looks like it will be in the way About to get into a sport
Post #394279 Sun Sep 08 2013 9:34am
Disco_Mikey
If you have factory fit Brembo's, then you have DR.
The bottom part of the fan cowling does not need to come out Thumbs Up
Post #394280 Sun Sep 08 2013 9:36am
Simon58
it has Brembos so I assume I have then - will have another look later today after the F1 About to get into a sport
Post #394289 Sun Sep 08 2013 12:09pm
Simon58
So alternator replaced, got a denso one from Eurocar Parts £176 inc vat (using discount code) car starts ok voltage good at battery after about ten minutes battery warning light comes on!!!!! ......................... NOW WHAT!!!!! About to get into a sport
Post #394740 Thu Sep 12 2013 8:19am
flack
There have been a few posts of members buying alternators from Euro car parts and them failing shortly after, if this is the case then you need to get it replaced .
But first check your battery as the old alternator failing could have damaged your battery.
Flack Thumbs Up
Post #394751 Thu Sep 12 2013 9:41am
mdcbigdave
Site Sponsor
My bros RRS had the battery light on for a few days.
Then failure and it has goosed his battery completely.
Its a TDV6 too.
When mine went on my D3 last month I disconnected the battery immediately and its ok.
Fun innit! Thumbs Up All things transport and logistics, international and national shipping.
Its a small planet after all.
info@md-couriers.co.uk
Post #394752 Thu Sep 12 2013 9:43am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Euro Car Parts do 2 alternators one with a 1yr warranty and one with 2yrs I went for 2yrs and have had no problems at all.. Thumbs Up
Post #394758 Thu Sep 12 2013 11:11am
Simon58
Turned out be the 'Alternator Link Wire' was faulty which probably caused the alternator failure to start with, wire replaced and all working now - thanks for the advise and pointers
Simon About to get into a sport
Post #394783 Thu Sep 12 2013 5:03pm
