Home > Technical > Rough idle on 2009 RRS 3.6 tdv8
PKS
Australia
Hi everyone.
I have a 2009 RRS 3.6 TDV8 with 75,000 km.
It performs faultlessly in all regards except one.
When you start it, it idles extremely smoothly, but after 10 to 20 seconds it settles into a rough idle, shaking the steering wheel and being felt through the seats.
If you stop and turn off the ignition and then restart it sometimes starts smoothly again, before going into its rough idle, and sometimes it will restart and immediately go into its rough idle.
Your collective wisdom and knowledge on possible causes and remedies would be greatly appreciated.
Regards, Peter from Australia
Post #392832 Sun Aug 25 2013 8:46pm
Camelrock
Could be an injector harness fault it might show up which one with diagnostic tool.
Post #393459 Sun Sep 01 2013 7:27am
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
I would say egr valve
Post #393480 Sun Sep 01 2013 6:41pm
PKS
Australia
Thank's for replies so far.
What is the best diagnostic tool to get for this model?
Also, since first post, problem seems to be getting worse. eg happening nearly all the time.
It still starts with a perfect idle first thing in the morning and then between 10 and 40 seconds drops into its rough idle.
Would a diagnostic tool show if it was the egr valves?
Also can the egr valves, linkages etc be lubricated from the outside?
Is it a difficult job to replace the egr valves?
regards, Peter
Post #393510 Sun Sep 01 2013 11:35pm
cossiedave
mine used to do this so i bought some egr valve cleaner, you can take the 2 black pipes that go to the throttle body off and spray the cleaner in while reving the engine at 2-3 thousand revs, give it a try as replacing the egr valve on a tdv8 is a big job , i have the launch dia gun which came up with codes for egr on mine
Post #393512 Mon Sep 02 2013 7:00am
PKS
Australia
Hi Cossiedave,
thanks for your reply. Which 2 black pipes are you talking about? Are they the elbows that are attached to the aircleaner near the MAF sensors? Any pictures?
Regards, peter
Post #393605 Mon Sep 02 2013 9:39pm
cossiedave
the 2 big black pipe to the out side
Post #393613 Mon Sep 02 2013 10:56pm
PKS
Australia
Thanks I will give it a try and report back. Peter
Post #393615 Mon Sep 02 2013 11:14pm
cossiedave
http://www.ebay.co.uk/itm/Kalimex-JLM-Dies...257a9c1ba9
Post #393621 Tue Sep 03 2013 6:59am
PKS
Australia
Hi all,
I have take vehicle to an independent specialist. He put the diagnostic test ester on, it had some 12 miscellaneous faults show up, cleared all of them and then went for a 10 minute drive. Come back and connected diagnostic tester. All clear, but rough idle still there. Put the egr cleaner through as suggested at 2000 rpm, unfortunately made no difference. His only thoughts where to suggest a smoke test on inlet system, looking for leak, or possible faulty injector.
Any thoughts or suggestions would be appreciated.
Only difference from first post is it is idling rough more times than smoothly now.
Regards, peter
Post #393906 Thu Sep 05 2013 10:17pm
ross24061986
TDV8 ROUGH IDLE JUDDER COLD
I have a 2010 rr sport done 157000, full genuine Land Rover servicing by myself as I work for main dealer.
I have tried all but a few items now to resolve the slight judder/ misfire sensation when the car is only cold on start up.
Here is my shopping list already done and tested out so far people: ps all genuine parts
2 new mass air flow meters
2 map sensors
2 top turbo hoses
2 turbo Actuator checks all ok
2 turbo to inter cooler side bore scope camera checks for oil all ok
2 turbo out out shafts checked for play when exhaust was off all ok
2 throttle bodies
2 egr valve head checks all ok
2 rocker cover checks all ok
1 new crank case breather replaced
1 oil filter iand oil of castrol magnatec 5w 30 A5
All fluids drained gear box sump pan and replaced with lr parts and lr oils
Well that's about it, apart from if I put my ear to the drivers wheel arch it makes more of a bop bop bop noise than the
Passenger side.
No dtc's logged in sdd just a chatter noise with the misfire also.
Has anyone repced the timing chains yet cause that's my next job and its BIG!
Post #497226 Sat May 28 2016 8:53pm
