![]() | Home > Maintenance & Modifications > Bleeding fuel cooler - necessary? |
If you have changed it and the car is running fine with no problems then your ok, not all the ones I have disconnected have needed bleeding some are ok and others do need bleeding..
Thanks Flack you are a gentleman. Only had it idling until up to temperature so far but will take it for a run later. What would the symptoms be if there is air in the fuel cooler? Is it like vapour lock? 2008 MY Java Black TDV8 HSE
No it might run lumpy at idle or miss a beat when you clog it but it should self prime, just give a blast down the road and see if its running ok.
