Home > Maintenance & Modifications > rrs tdv8
jer4x4@hotmail.co.uk
United Kingdom 2007 Range Rover Sport TDV8 S Java Black
rrs tdv8
how do you bleed the fuel filter
Post #393131 Thu Aug 29 2013 12:06pm
Welcome to the site. Thumbs Up
The site has a great search function Wink Whistle
For the TDV6
http://www.rrsport.co.uk/forum/topic20621....uel+filter
And a link with some piccy's
http://www.disco3.co.uk/forum/topic32281.h...r+%2Bbleed
http://www.rrsport.co.uk/gallery/albums/us...urrent.pdf ON THE WAY: BMW F21 M140i
Post #393132 Thu Aug 29 2013 12:14pm
Paddi
Those links are all to TDV6 related information. The TDV8 filter is a different design. After changing the filter it should only be necessary to switch on the 'ignition' without starting the engine and wait for the fuel pump to stop. Repeat that a couple of times and the system should self-bleed. If that step is missed or fails then there is a fuel bleeding point under the engine acoustic cover; look for a short armoured hose with grey cap on the end. Under the cap is a Schrader type valve. Get your assistant to switch on the ignition and while the pump is running use something to press the centre of the valve and try to catch the fuel in jam jar and minimise spills with a large piece of rag. Then clean the fuel up where it has squirted everywhere. 2008 MY Java Black TDV8 HSE
Post #393286 Fri Aug 30 2013 9:40am
Embarassed Whistle
I still stand by the search function comment Wink ON THE WAY: BMW F21 M140i
Post #393291 Fri Aug 30 2013 9:53am
muddywheels
Milk Float Man
BC you're slipping Shocked
Maybe riding that bike's getting to you Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #393293 Fri Aug 30 2013 9:55am
Moi Question Whistle Laughing Sad ON THE WAY: BMW F21 M140i
Post #393297 Fri Aug 30 2013 9:58am
muddywheels
Milk Float Man
http://www.motortrades.co.uk/company.asp?c...ny=jer-4x4
Bit worried the trade are asking us for advice though Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #393299 Fri Aug 30 2013 10:02am
Shocked Shocked ........now that is funny Rolling with laughter
4x4 specialst Rolling Eyes........just not at bleeding a TDV8 Whistle ON THE WAY: BMW F21 M140i
Post #393317 Fri Aug 30 2013 11:35am
Paddi
No worries BC Thumbs Up I was slightly out too. Knew there was a proper answer from Bobby somewhere and here it is:
http://www.rrsport.co.uk/gallery/albums/us...20TDV8.jpg
Trade using forums? Sometimes I think they don't use them enough - must be a pride thing Rolling Eyes 2008 MY Java Black TDV8 HSE
Post #393323 Fri Aug 30 2013 11:57am
muddywheels
Milk Float Man
Well said paddi Bow down
I am going to prepare a thread on how to swap plates next for lr technicians - ie how to clean off old sticky tape and seal old holes before fitting replacements Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #393328 Fri Aug 30 2013 12:11pm
Paddi
^^ Rolling with laughter Rolling with laughter Rolling with laughter
You mean how to not do this as found under my rear plate?:
or this under the front plate:
Post #393329 Fri Aug 30 2013 12:22pm
Rolling with laughter ....no more nails is so under rated as a product Shocked ON THE WAY: BMW F21 M140i
Post #393330 Fri Aug 30 2013 12:25pm
