![]() | Home > General > Low Range Needed or not. |
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
Now the new RRS is making low range a pricey optional got to thinking is it really needed |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154
Low range can be useful when towing too; it's not just for serious off roading.
| mlines Member Since: 10 Dec 2006 Location: UK Posts: 480
Used every week (towing) 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
| muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644
I have towed a big twin axle for 3 years, always stay on farm sites in fields and have also pulled motorhomes out that have got stuck but never felt I needed low ratio |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
In the sport ive used low range twice "off road" but a few times towing (not this one last one)
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
I used the low range box when we had snow earlier this year to give me some better traction and control up/down some slopes as I was (and am still) running Conti Sport Contacts. ON THE WAY: BMW F21 M140i
Caravans aren't that heavy compared to what the RRS can and does tow though. Low range comes in useful when towing heavy loads on long inclines where speeds can get low. It's better for the gearbox if you use low range in these circumstances - long slow towing in high range can overheat the gearbox. It's also useful in situations where you might otherwise need to ride the brakes on a long slow descent, particularly in slippery conditions. As mse says, low range is just another set of ratios and have their uses away from muddy places 2008 TDV8 - it was a labour of love and is much missed |
| zango1 Member Since: 06 Mar 2012 Location: London Posts: 27
I grew up in the middle east and off-roading on the sand dunes never required low range. I hadn't ever thought about towing to be honest.
If you're worried about the mpg effect of the weight of a low range box on a 2.3-2.5 tonne vehicle then I think you're buying the wrong vehicle in the first place.
Its the low speed handling it give you when towing.
All the sand driving I've done...big sand pits, more than dunes, you don't want the torque of the low range box...which is why you never needed it Mike 2014 Facelift Discovery |
I use mud ruts setting to reduce throttle response when I'm towing and want more control Still hoping for a S2 one day! |
Low range gives more control in some situations. M&R on it's own is good, M&R + LR is better. Selecting an off road programme gives you the locking centre differential. Adding LR gives lots of control going down hill as well.
