![]() | Home > General > Another silly question |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
They dip to help when reversing although I didn't like it so I disabled it on mine.
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
Many thanks for that, got a feeling this will end in tears, but will gie it a shot.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
You need to do it for each key too don't forget. 2012 SDV6 - it's missing a couple of cylinders
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
its pretty easy to change setting mate |
Unnecessary quote removed
If you go into settings menu on the dash ( engine running but in park) you will find a subject " mirrors dip". If to toggle that with the bottom right button on steering wheel to off they won't dip when selecting reverse. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Why? Can't you read? ![]() 2008 TDV8 - it was a labour of love and is much missed |
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 ![]() ![]() ![]() |
Personally I like that function.
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
Turned the dip function off on mine. Was good on the D3 for coming out of the garage but the RRS seems to dip further and points almost straight down |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
marsie,
Ok I liked this function on the D3.
See my post three above! 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
This, along with almost every other "how do I switch X on/off" type question is dealt with in the manual. |
