![]() | Home > General > towing with MY13 - park assist disabled |
I abit of a jump from 06 to 13my!
Sounds like there is something wrong. Mine stops rear sensors only and as soon as plug pulled they start beeping away. 2x TDV6. SE and HSE. Both returned to sender with issues👀
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Hmm, mine go to a solid beep when reversing as if I am already 6" away from an object (on a MY10) it must be picking up the A frame, or it might be hard wired to do that, I don't know. Generally I switch the car off when disconnecting the trailer anyway, so can't comment on your switching on/off problem.
That's because they aren't enabled ![]() 2014 Facelift Discovery |
Ahh, silly me! I thought if it wasn't enabled it would be silent!
When enabled i recall you get a beep to show they are on then nothing unless something approaches the front. Mike
amantium Member Since: 30 Apr 2013 Location: Northeast Posts: 5 ![]() ![]() ![]() |
Thanks all for info. Yes Mike, it was a bit of a jump but I liked my 06 model (except fuel consumption was very poor) and didn't feel the need to replace it 'til it started costing so much at MOT time. I love the new one - lots of new gadgets like the power boot (altho I miss the split rear door) but really must get this towing thing sorted otherwise it'll be going the journey. I have horses and I really need to be able to tow safely and manoeuvre in some pretty tight places. Is there any chance you might be able to plug a trailer/lighting board into yours to test it for me to confirm exactly how it works? The dealer reckon they fitted electrics to a Disco recently and the park assist was off all round. They couldn't say if it recognised when disconnected as they didn't try this.
I would test it for you...but one of the reasons i cant is i have a 13 pin (deliberately) and havent got an adaptor yet.
Apparently you cannot take the manual as gospel because LR "reserve the right to alter the specification without notice". The dealer has said the only way to tell if the electrics are working as they should is to find another 13MY. |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
My front sensors not working either when towing - did you get this sorted amantium |
I recently traded in a MY10 and towed with it for 3 years - the rear sensors were disabled when towing but front were still active |
Ive not used the tow electrics my 13my (and probably never will at this rate) but on the 11 they definitely left the front on.
The third thing Mike is to tell the gearbox to start in first.... And on the pre 8 speed, to stop it selecting 6th but not sure on the later boxes. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sorry guys but I haven't been able to get mine sorted - just putting up with it at the mo. It is very frustrating though and like MW, I can't understand why LR would change such a useful feature, unless they are trying to get us to buy their camera option (although I don't know if that can be retro-fitted)??? If anyone does find out if it's possible to disengage just the rear sensors, please let us know. |
