| RRSPORT.CO.UK | ||
|  | Home > Technical > Air con compressor |
| Preston-rr Member Since: 10 Sep 2010 Location: Preston Posts: 239      |
 Hi all, my air con isn't cold. I had it regassed was ok for 1 day. Went back said it could be the compressor but let's try the in can pipe sealer stuff, forgot the technical name. Worked for maybe a week now to cold again. Is it my air con compressor that needs changing? Can they be fixed? If not how much is a new one?
|  Wed Aug 21 2013 7:13pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | I doubt its the compressor it's more likely to be the condenser or dryer that has a leak in it..when they did the regas did they do a leak check with a uv light source..
|  Wed Aug 21 2013 7:39pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | As Flack says, it is does not stay cold, there is a leak somewhere. Most common is the condensor, and very reasonably priced from site sponsor Advanced Factors   | ||
|  Thu Aug 22 2013 6:02am |
| Posting Rules
