![]() | Home > Technical > Can anyone identify this? |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
I have got one too, on the drivers side? The connected plug appears to have 2 terminated wires in it as though it is meant as a blank. Cant see where its supposed to go? wondered if it was maybe a brake pad wear connector?
Found a similar thing behind a headlight and posted a similar question. Disco Mikey ID'd it as an unused part of the loom for TPMS.
That could be it |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4503 ![]() ![]() ![]() |
Rear TPMS receiver connector |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
Cheers guys - now just got to find where it should be fixed |
Look at the rear wheel arch liner; there are two holes about halfway up the rear side. The 'fir tree' lug on the connector should be plugged in to either one of the holes from the outside of the liner. No idea what the other hole is for though ![]() ![]() |
Cheers |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Yep, that's right Muddy. I had the same thing with my 09, it fell down after a dirt road (winery) trip. I stuck it back in the rear wheel arch housing and it didn't drop down again. I may have helped it with a little tape if I remember. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
