![]() | Home > Off Topic > A Few Changes We Should Be Aware Of |
The key is clear its about what you can see...which was my point.
I think my interpretation is correct and further comment covered the extended by the fixed extended arm mirrors on a defender which are designed so you dont need extension arms...they are already extended and fixed. Its all about the field of vision you have - if you can clearly see in the red area of the diagram then it isnt illegal Defender example ![]() 2014 Facelift Discovery |
What im saying is that if you can see the red area with the car/trailer combination you have then you are definitely ok - thats simple.
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 ![]() ![]() ![]() |
It's nice to know the people on this forum know what mirrors are for at all, driving up the M5 today it seemed most people didn't even know they had mirrors! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9137 ![]() ![]() ![]() |
As mse has pointed out, you're only breaking the law if you can't see in the areas highlighted in the diagram earlier in the thread. If, when seated normally in the driver's seat, you can see in your mirros everything within those areas then you are not breaking the law by not fitting additional mirrors. The law requires you to be able to see rather than fit mirrors. "You may require extension mirrors" is not the same as "you must fit extension mirrors". When I fit my RRS to the front of our horse trailer I can see down the side of the trailer with the normal mirrors. The trailer is wider than the vehicle, however, because the wheels stick out further than the sides of the trailer by same distance. So, the trailer is wider than the vehicle but you can see down the sides of the trailer body thus it's legal. As it happens, I fit extension mirrors because it allows me to have mirrors angled down to the wheels of the trailer so I can see where the wheels are when turning. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Read what I said. Not all trailers that are wider than the vehicle block the view to the rear. The wheels stick out wider than the vehicle but the body of the trailer is narrower than the vehicle. So the trailer, as a whole, is wider than the vehicle but the mirrors can give adequate vision to the rear.
So now we have all been educated on which mirrors to use when towing... |
Day at work had...instead of a drink break |
![]() Im not sure you have grasped the concept of the law either if im honest...so its worth leaving it there. I certainly will be ![]() ![]() ![]() Ive stopped watching this post now to resist the temptation to post. When did you pass your trailer test by the way? Mike 2014 Facelift Discovery |
This made me smile the other day when i was out and about. |
They have equivalent MOT's for HGV trailers
and
and
I referenced the defender mirrors (you also supported this with your tractor comment) - by saying, thus the mirrors not being bolt ons, being permanent extensions eg new mirrors for the car, the new car standard mirrors (like lorries and tractors), but enabling you to see into the red area. RRSTDV8 also added
and clarified my Mitsubishi point (RRSTDV8):
Open Gov says, for the DVLA (key items added in bold):
Available: https://www.gov.uk/towing-with-car/towing-...-standards - there are other bits of useful advice So what I/we are saying is: You might need (and it would be right to have) extended mirrors fitted, if the mirrors fitted to your car (modified permanent extensions (tractor or defender say or standard fit on x car) dont provide you the required level of vision (the red area on this diagram http://www.lifesure.co.uk/cms/wp-content/u...24x589.png ). If the mirrors fitted to the car didnt allow you to see the area in red, you would be breaking the law and that is very bad and generally dangerous. However, if your car is suitably equipped, you are not required by law to have extended mirrors fitted...you are required by law to be able to see and you are able to achieve this through the fitted mirrors. Thats clear in the government advice. I dont think it really matters or is worth getting worked up over, i dont actually think we are fundamentally saying something different, other than you assertion that when you put a trailer on the back, the law says you must have extended mirrors fitted - which it doesnt. Anyway after typing - what might be the longest post, ive realised, not only have i wasted my life - bored myself and everyone else...but actually this is only MIRRORs on A CAR!! its hardly world peace. ![]() Finally - i really dont hold a grudge, i hope you wont and i promise martin and others i will NOT post again on this topic ![]() ![]() ![]() 2014 Facelift Discovery |
