![]() | Home > General > Nav Help |
Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42 ![]() ![]() ![]() |
I've just purchased a 55 sc and have found that the Nav is showing no signal (red line through icon) the previous owner has said it's got the 2012 disc in and needs an aerial upgrade? Is this true, and if so can I just put an earlier disc in and get it running?
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Is it a 2012 disc for a 2005 car, or is it a disc from a 2012 car (which will not work)? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
2012 don't have discs so it must be a 2012 disc Mike
Thanks for the replies, I'll have a rummage around tomorrow and check the connections. 2011 Evoque Si4 Dynamic plus lux
All of the connections seem good, and I've checked the disc, it says 2011-12. As the maps all load ok so I'm guessing it must be the receiver. I'll confirm when I receive the replacement.
