Home > Maintenance & Modifications > Front suspension arms
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Just got my RRS back from the dealer after complaining about knocking noise, and have been told that my front lower suspension arms are worn and need replacing.
So will be looking to get it replaced ASAP. Can anyone advise what else I should replace whilst its in for suspension arms?
Thanks 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #391882 Thu Aug 15 2013 8:55pm
Advanced Factors
Site Sponsor
I would do the whole lot....
ARB Bushes, Inner & Outer Track Rods & ARB Stabiliser Links
It will feel much better for the set. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #391900 Thu Aug 15 2013 10:28pm
JasM
Thanks for the reply.
Sounds expensive! How much extra am I looking at?
I have always tended to stick with genuine LR parts. Are the aftermarket ones any good or better?.
Also forgot to mention that my RRS has dynamic response, not sure whether that makes any difference. 2014 L405 SDV8 RR Autobiography Cool
Post #391901 Thu Aug 15 2013 10:38pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
You will have to cut the arms off as I did
Got my bits at a very good price from. Him^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Him
Post #391903 Thu Aug 15 2013 10:40pm
ShooterNeil
Parts come with 2 year warranty from AF
Post #391904 Thu Aug 15 2013 10:42pm
JasM
Sounds good.
Did you just replace the front arms or was there any additional work carried out? 2014 L405 SDV8 RR Autobiography Cool
Post #391905 Thu Aug 15 2013 10:49pm
ShooterNeil
I did the ARB bushes /lower arms and track rod ends
Still have the drop links and inner tie rods in the shed but they are ok for now as have no play
Post #391907 Thu Aug 15 2013 11:03pm
JasM
I take it that has pretty much eliminated the knocking noise? 2014 L405 SDV8 RR Autobiography Cool
Post #391909 Thu Aug 15 2013 11:09pm
ShooterNeil
Yes but a right pig to do
Post #391911 Thu Aug 15 2013 11:18pm
I found that new ARB bushes cured the knock from my suspension. I had the front arms done recently as one was apparently showing signs of excessive wear. LR garage asked me why I was changing both sides when only one side was showing the wear. Seemed a bit confused that one might do both whilst doing one. 2012 SDV6 - it's missing a couple of cylinders
Post #391913 Thu Aug 15 2013 11:36pm
Disco_Mikey
Front lower arms are a doddle to do, if you go into the job knowing the bolts will need cut out, and you possess a 9" grinder Thumbs Up
If you go in expecting everything to be free and easy, you will be massively dissapointed Laughing
If you have access to said big grinder, the arms take around an hour to get off, and same again to refit. Also, best to allow for a wheel alignment ASAP afterwards
Post #391918 Fri Aug 16 2013 6:49am
Local LR dealer that did mine said that an alignment wasn't usually necessary! I told him to do it anyway "just in case". 2012 SDV6 - it's missing a couple of cylinders
Post #391947 Fri Aug 16 2013 3:21pm
JasM
Don't worry, I won't be doing the work. I have booked it in with yourselves at Strathearn, so hopefully it won't give you too much trouble. 2014 L405 SDV8 RR Autobiography Cool
Post #391962 Fri Aug 16 2013 4:55pm
