![]() | Home > Technical > lower arm knocking vs roll bar clunking |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4507 ![]() ![]() ![]() |
They do sound very similar.
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
Thanks mikey 07 TDV8 + BAS map |
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 ![]() ![]() ![]() |
I found a big lever bar between lower wishbone & ARB showed up 2mm play in my N/S front lower BJ. Couldn't get any play in ARB bushes.
2 hours...some indy is charging £260 for that. thats more like 4! 07 TDV8 + BAS map |
Ah, well it's all the excellent virtual training I've had! 2006 TDV6 SE, Zermatt Silver |
And indy charging £130 per hour ![]() Need to get my ass down to London ![]() |
s335 Member Since: 05 Aug 2012 Location: essex Posts: 12 ![]() |
You can tell the difference. Usually if you tap the brakes like a cadence braking and it knocks its the lower arms and if you shake steering wheel side to side at low speeds it usually the anti roll bar bushes |
