![]() | Home > General > FRONT SEAT removal?!? |
Quite easy actually...
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 342 ![]() ![]() ![]() |
Many thanks...that's exactly what I needed to feel confident to to the job. Some one mentioned that there might be issues with air bags? Have you any experience or thoughts?!? Andrew Kennedy |
You shouldn't have any issues if you disconnect the battery earth |
Thanks again for coming back. I am almost feeling I can get on with the job of taking the seat out.....but I dont like the word SHOULDN'T.....I would prefer the work WILL NOT. What do you think? Andrew Kennedy |
Just make sure the SRS system is rendered safe.
If you disconnect the battery you won't...... Better? Worse thing you can do is turn on ignition while seat is out and you'll need air bag light switched off. |
