Home > Technical > Supercharged power lost. Coolant pump?
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Lost power today and limped home,no messages on dash. Noise coming from electric pump. Wired incorrect? Can I just cross over wires or will I need a new pump? Fault codes recorded,p2601 and p0504. Many thanks. This happened after a good thrashing in sport mode.
Post #390179 Sat Jul 27 2013 2:43pm
SCdavies
FYI. New electric coolant pump and all sorted. Rewired it as well to correct configuration. So be warned that if your has not been done it can let go at anytime. Thanks
Post #391076 Tue Aug 06 2013 6:58pm
tanloverluke
why did you have to rewire it, is it incorrectly wired by default ? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #391085 Tue Aug 06 2013 8:39pm
Disco_Mikey
Yes, it is a known issue. The terminals on the connector are the wrong way round, so the pump runs backwards Rolling Eyes
Post #391104 Wed Aug 07 2013 6:57am
tanloverluke
thanks for that, i'll check that out as soon as i get back from my hols ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391106 Wed Aug 07 2013 7:07am
