Home > Technical > Hard reset!!!
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Hard reset!!!
i have been told a hard reset is to join the pos and neg together for 20 mins...anyone done this? what does it actually do? thanks.
Post #391049 Tue Aug 06 2013 1:26pm
garrycol
Australia
Join them together after removing cables from the battery - they only need to touch and do not need to be held for 20 minutes. The purpose is to remove any stray voltages in the system that may be keeping any memory alive.
Is the same as switching off your home computer and rebooting it after some clitch.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #391051 Tue Aug 06 2013 2:08pm
SCdavies
many thanks
Post #391059 Tue Aug 06 2013 3:03pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Sorry to re-awaken such an old thread but I'm thinking of doing this on my 2010. Like Garry said, it's the same as doing a full shut down on a PC to clear the memory.
My question is; Would you guys recommend doing this every month just to keep all the systems sharp or is this something you should only do as a troubleshooting step to see if it rids the car of any glitches? Also, will this affect the 2010-13 models differently than the 2006-09?
Post #526507 Mon May 22 2017 2:25am
d-9
Troubleshooting only. No need if everything is working properly.
Post #526516 Mon May 22 2017 10:13am
garrycol
Australia
I agree - not needed unless you have a niggling problem that will not go away. It is simple and no cost so has always got to be the first action to attempt to fix an issue.
But only if there is an issue.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #526518 Mon May 22 2017 10:54am
CANROVER
Thanks guys..... for the longest time I've had the Extended mode issue where the car thinks there's an obstruction under the chassis when I go into access mode and I have never tried this. Do you think this may help? I'm thinking, "wouldn't hurt to try."
Post #526554 Mon May 22 2017 8:14pm
garrycol
Australia
I dont think it would help but wont hurt.
If the car is raising when hitting access height - my guess would be that the suspension needs recalibration or maybe there is a faulty sensor.
I run my car on LLAMS at -20mm and sometimes the same happens to me when lowering to access = locking normally overrides the problem.
However in your case try recalibrating the suspension (not sure how it is done but is easy - you will need to research) should fix your issue - if not look for a faulty height sensor.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #526581 Tue May 23 2017 2:53am
d-9
Mine does that occasionally, according to the garage it's a slightly dodgy height sensor issue.
Calibration is done with something like a iidtool and a ruler.
Post #526582 Tue May 23 2017 4:11am
CANROVER
The IIDTool makes it pretty easy to recalibrate. I did a quick recalibration a few weeks ago with my IIDTOOL but I'm not sure if I did it to the letter so as to get everything back to stock. I just looked at what I had and made the front ones even and then the back ones even although slightly higher. I tried to find a "reset to factory specs" setting but there isn't one. I'll try again today.
Thanks guys
Post #526593 Tue May 23 2017 12:21pm
CANROVER
Ok I just did it and I think I gained an extra 200hp Rolling with laughter
Post #527275 Wed May 31 2017 8:52pm
