Home > Maintenance & Modifications > Engine smoke
K80tcg
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Engine smoke
Hi I have a tdv8.
Which smokes on hard acceleration. It also smokes on mild acceleration.
If you let the throttle off and reapply cloud of black smoke appears.
Is this something to worry about.
Any ideas? Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #390553 Wed Jul 31 2013 7:08pm
TDV8s will puff more soot if mapped... do you know if yours is?
If you're experiencing lower performance too, then check the two intercooler pipes that run from the top of the intercooler to the manifold (right at the front of the engine on top of the rad) RRS gone
Post #390591 Thu Aug 01 2013 8:29am
SRE
Spain
My TDV6 2.7 smokes a fair bit when booted hard, kick down etc, it is a little worse with the remap, I think it will be a LOT better once we are able to blank the EGR valves though. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #390618 Thu Aug 01 2013 1:28pm
K80tcg
Hi my car is not mapped.
The smoke has got worse over the last couple of weeks, silly question nothing to do with the hot weather?
Reading through the forum, says about EGR valves how do you know if these are knacked?
I will look at the intercooler pipes, Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #390631 Thu Aug 01 2013 3:50pm
K80tcg
Just I though I filled up with shell v power would this make it smoke more as it is cleaning out the crap? Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #390646 Thu Aug 01 2013 6:59pm
K80tcg
Found the problem as you said intercooler hose. These from main dealer only how much?
Or are there silicone ones available ? Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #390827 Sat Aug 03 2013 6:40pm
