Home > General > Gear box oil and filtering change?
rabcnesbit
Anyways, was having a chat with my indi and mentioned the fact that sometimes, there's this juddering/jerking that occurs when the RRS is pulling off. He advised me that changing the gear box oil and filter has been known to cure this. So I asked him how much this will cost me, and he quoted me £492 inc vat! Madness! I think I will just have to live with.
Post #390069 Fri Jul 26 2013 7:28pm
flack
rabcnesbit
Get some Dr Trannys two tubes from here and stick it in your gearbox when the oil is warm you might need to remove some oil to fit it in.
http://www.advancedfactors.co.uk/transmiss...3-14-c.asp
This will be a cheap fix for you
Flack Thumbs Up
Post #390072 Fri Jul 26 2013 7:51pm
Advanced Factors
Site Sponsor
The ZF 6HP26 box can suffer lack of shutter lock in the torque converter, common when your oil is over 50k miles.
Try a tube of Dr Tranny in it (we sell loads for D3s, its a well documented fix)
If it works then it's telling you new oil time, cant tell what you are driving but most likely you need £100 worth of oil then a choice of filter/sump type.
Have a look on our website...
http://www.advancedfactors.co.uk/transmiss...t-24-c.asp Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #390073 Fri Jul 26 2013 7:52pm
rabcnesbit
Flack and Steve, many thanks for your suggestions. Will look into it. Thumbs Up
Post #390086 Fri Jul 26 2013 10:05pm
simple1
Funny that, my Vogue is doing something similar more like a slip in drive but according to Guy Salmon there is nothing wrong. It doesn't like pulling away or accelerating with trailer/caravan on the back. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #390095 Fri Jul 26 2013 11:01pm
Re: Gear box oil and filtering change?
I had mine done by an indie for £190 incl. 2012 SDV6 - it's missing a couple of cylinders
Post #390098 Fri Jul 26 2013 11:50pm
rabcnesbit
That's not a bad price RRSTDV8. Shame you are based in Northamptonshire. When did you do this and did it cure the problem? Thanks
Post #390182 Sat Jul 27 2013 3:03pm
Advanced Factors
Site Sponsor
I am in the process of sorting out the importation of a Transmission Flush machine, hopefully sometime in August there will be a mobile option within the site sponsors, so correct oils, and other work at the same time if needed. Paul Redding
+44 (0)23 8052 2776
Post #390187 Sat Jul 27 2013 4:19pm
rabcnesbit
Looking forward to this. Thumbs Up
Post #390193 Sat Jul 27 2013 5:02pm
Had it done earlier this year - just had it done as part of general maintenance as the vehicle had about 60k miles on it at the time. I reckon LR's 10 year interval is too long. 2012 SDV6 - it's missing a couple of cylinders
Post #390194 Sat Jul 27 2013 5:17pm
SRE
Spain
I Think Embarassed I read (I think on the Disco 3 forum) that you can get a "better" metal sump for the auto box, that allows you to change the filter separately. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #390199 Sat Jul 27 2013 5:37pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Gents, I ve been told that our gearboxes are a sealed for life and don't touch them. This also includes the supercharger oil. Have I been told porkies by land rover?
Post #390213 Sat Jul 27 2013 6:01pm
Disco_Mikey
"Sealed for life" is open to interpretation Rolling Eyes
The life of the car?
The life of the gearbox?
The life of the oil?
If it's the life of the gearbox, then it's too late.
If it's the life of the oil, I would want it done sooner, before the oil is completely Censored
If it's the life of the car, why is there a replacement interval of 150k miles/10 yrs?
IMHO, around 100k miles it should be replaced Thumbs Up
Post #390224 Sat Jul 27 2013 7:13pm
I believe that ZF themselves now suggest that the transmission oil should be changed 80-120k km depending use. So if you run at high speed or tow regularly or go off road then you need to consider changing the transmission oil more regularly than the 10 years given by LR in the maintenance schedule. 2012 SDV6 - it's missing a couple of cylinders
Post #390234 Sat Jul 27 2013 10:20pm
