| RRSPORT.CO.UK | ||
|  | Home > General > Range rover sport lowrering links help? |
| cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882      | hi mate i have lowering links on mine and if i put it in access mode it lifts straight back up again but drive normal when up, i do get a suspension warnig light on now and again tho , links take about 30 minutes to change | ||
|  Tue Jul 16 2013 10:07pm |
| f1_1rfn Member Since: 28 Jun 2013 Location: UK Posts: 15  |
 Thanks for reply.. So when your in normal driving mode your car sits low? And when you choose access mode it raises to normal drive height and stays there no matter which speed? Where did you get yours fitted? Thanks | ||
|  Tue Jul 16 2013 10:27pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | If you fit lowering links then the height the links give is the new "normal" height. If you choose "access" then it will bottom out and return to the new "normal" height i.e. the height set by the links. If you choose "off road" then you'll get a 50mm increase in height but it will return to "normal" at approx. 30-35mph.
|  Tue Jul 16 2013 10:40pm |
 Thanks for reply is this what i need? http://item.mobileweb.ebay.co.uk/viewitem?itemId=190687032386 | ||
|  Tue Jul 16 2013 10:57pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | That will allow changes to be made to ride height. Use it carefully, however, as the Sport is quite sensitive to suspension set up and if done incorrectly then you can eat through tyres. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Jul 17 2013 6:51am |
 thanks i ordered the EAS unit glad i posted a thread here otherwise would of bought the lowering links   | ||
|  Fri Jul 19 2013 7:27pm |
| cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882      | THATS A LOT BETTER SET UP THAN THE LINKS | ||
|  Fri Jul 19 2013 9:23pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | I have the EAS unit it does  'what it says on the tin' cracking piece of kit but be aware as previously mentioned even the IID tool can cause tyre problems & It does make a difference to the ' ride ' a lot more sensitive - especially speed humps & potholes  | ||
|  Fri Jul 19 2013 9:31pm |
 I have had previous cars with rock solid coilovers nearly touching the ground lol so ride dosnt bother me   I paid £225 delivered which was exactly what the links guy was charging supply and fit.. Cant wait to get my car back from paint so i can lower it and post some pics up   | ||
|  Fri Jul 19 2013 9:50pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | What are you driving ? - only your profile isn't showing your RRS   | ||
|  Fri Jul 19 2013 9:57pm |
| f1_1rfn Member Since: 28 Jun 2013 Location: UK Posts: 15  | I got a 2.7 tdv6 bought it totally standard in silver so gathered all the parts to transform it  | ||
|  Fri Jul 19 2013 10:01pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | I would only consider  1 other colour RRS   | ||
|  Fri Jul 19 2013 10:05pm |
| f1_1rfn Member Since: 28 Jun 2013 Location: UK Posts: 15  | Was thinking of doing something diffrent like matt grey or a bright colour but i dont think it would look that good so chose a real nice creamy pearl hopefully should look good ! | ||
|  Fri Jul 19 2013 10:14pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | I work at Jaguar - the new F Type in red is something special - If I won big money I'd order a new RRS in the same colour & a helicopter   | ||
|  Fri Jul 19 2013 10:19pm |
| Posting Rules
 weddings & prom nights
 & a yacht
 & a yacht
