![]() | Home > In Car Electronics > Latest SATNAV disc? |
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 ![]() ![]() ![]() |
Purchased a 2006 RRS S/C this week and only found out it had no satnav discs loaded in
If you bought from a dealer he is legally obliged to provide you with a working sat nav unless he told you the disc was missing. He might even have it because a lot of dealers remove the discs whilst vehicles are on the forecourt to stop them from being stolen.
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Copied discs are reported not to work properly, and you should not use this site to recommend that people encourage copyright infringment |
Rsandsel Member Since: 18 Jul 2013 Location: Nottingham Posts: 15 ![]() ![]() ![]() |
Rich,
Point taken Martin, i'll shut up until i get the item and can judge it then. |
Thanks for the replys guys.
If you search on the LR official site there is a link to navigation updates. From memory the last update was something like 2012 but it is not up to date and LR have said there will be no further updates to the DVD version. Bearing in mind the standard sat nav is not very good and has a hopelessly unintuitive UI, there is a good case for just using a smartphone app instead. More accurate, faster, free updates and easier to use - oh and it doesn't shout at you over loud music.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
I would like to see a really nice RRS iPad mini install. It would be much better than the OEM sat nav, would stream music, allow internet use etc. I think the days of OEM installed stand alone sat nav must be coming to an end soon? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
OK this is me holding my hands up, what i received was a pirated copy, a damn good one, everything looked legit but the laser etched security code was missing off the disc which was the giveaway. Reported it and they are removing the vendors stock from their website. I have also returned the item to the vendor for a full refund and contacted LR, must have caught someone on a good day as they are sending me an update for just £50 as a result of me refusing the copy and reporting it.
^^^ Respect for being honest and karma sorted you out with a decent priced LR original |
Just ordersd a oem one from Duckworth |
michealewk Member Since: 23 Jul 2013 Location: ireland Posts: 9 ![]() |
How much are the real discs from landrover |
