Home > Technical > Whoo I fixed my cubby fridge
shepp
Finally the easter weekend has given me time to have a play with the big girl,
Firstly changed the spark plugs, I don't like leaving them 75k seems to long. Bit of a pain but got there in the end.
Then had a look at why the Cubby fridge was not working
Removed neg from battery
Removed the stereo surround
then gear knob
removed the ride and handling optimisation switch
then the upper floor console
remove the cubby lid, then the two torx screws on the front side of the fridge, sharp yank, and voila the cool box pops out.
I then plugged the ride and handling optimisation switch back in and re-connected the battery.
Then checked that i had permanent 12volt to the cool box
switch on the cool box and short across the diode and resistor as on the pic below. sorry poor pic as only thought to take pic when i was putting back together.
you should instantly see the switch light up and the cool box start.
This has just bypassed the low battery stop feature (which i dont need as only run while i am in car)
Unscrew th curcuit board and put a blob of solder on the back of the board, in corrolationto where you have shorted across, to make a permanent fix
Post #297169 Sun Apr 24 2011 10:03am
CUCO
Spain
anyone have a electronic scheme of this circuit???
I want to replicate it to get mine running in my D4 as the D4 are ign switched and I want to get the cool box running on aux batt to preserve primary one for starting purposes only but I don't want to get the aux flat.
Thanks in advance
Post #388663 Fri Jul 12 2013 6:24pm
