| RRSPORT.CO.UK | ||
|  | Home > Technical > Harshness, "smooth" grinding and high freq vibrati |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | There is a forum for the range rover vogue   | ||
|  Wed Jul 03 2013 7:51am |
| andrzejb Member Since: 15 Jun 2013 Location: Poland Posts: 8  |
 I know .. also a rangerovers.net however RRS with tdv8 engine is more popular (i thing x times bigger sale then in vouge) in the same time knowledge to share in that forum... rgds | ||
|  Wed Jul 03 2013 8:01am |
| Prelude Member Since: 29 Dec 2012 Location: Daan Saaf Posts: 57      | I think the problem is your front diff. | ||
|  Wed Jul 03 2013 12:56pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | I'd suspect a pinion bearing in the differentials.
|  Wed Jul 03 2013 1:02pm |
 only when on (means throtle pedal pushing  ) when I take foot off and braking using engine no symptoms rgds | ||
|  Wed Jul 03 2013 1:37pm |
 moreover I have checked microcat... no pinion bearings in my car as a seperated parts near diffs(both) Changeable parts are :pionion seal(front dif) one side bearing(small) and both sides seals all parts in front diff In the rear its only two bearing from both sides of diff with seals.... so? what do you mean saying pinion bearings? integral part with all diff? | ||
|  Wed Jul 03 2013 2:06pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | If noise is only when car's under power then I'd suggest the inner pinion shaft bearing (i.e. the diff. input shaft bearing) as its under pressure when the load is on.
|  Wed Jul 03 2013 6:05pm |
 But if failure ,diff needs to be changed yes? As i said no such a parts(bearings) from prop-shaft side available as a spare parts ...this bearing is inside diff as i see in microcat | ||
|  Wed Jul 03 2013 6:28pm |
 small update... after the rear pads and disk change (including hand brake parts) sound vanished.  ... harshness remains.... maybe its normal for that car   | ||
|  Thu Jul 04 2013 8:27am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Shouldn't be any harshness. If it is just at take up, I would be checking diff, gearbox and engine mountings and exhaust clearance/mountings. Also centre prop shaft bearings are known to fail at higher miles. New prop is £235 so dont bother to try changing carrier bearing   | ||
|  Thu Jul 04 2013 9:48am |
 gearbox checked mountings including exhoust checked propshafts no clearances even I hang on it bearings checked for clearnances and additional sound (car jacked and with free wheels drive) sounds is smaller however still exists and its ONLY for 1-2 seconds in some specific RPM during load (acceleration)from stop(1-2 gear) i when I ride and accelerate let say from some constant speed like 50km/h and up no noises.... | ||
|  Fri Jul 05 2013 9:54am |
 Today after the "noises" after the rear brakes change disapeared I clearly felt what is like with harshness and vibration
|  Sun Jul 07 2013 3:02pm |
| Stuart02 Member Since: 31 May 2016 Location: Melbourne Posts: 2    | Was there ever a resolution to this one, or was the prevailing advice of 'get rid of it' taken? | ||
|  Tue May 31 2016 10:50am |
| Posting Rules
 Having had both Sport and now Fullfat, take up is smooth and seamless. I did have a front diff failure last year that gave noise and harshness most noticed at around 25-30 mph and could be felt through steering wheel amongst  many other failures
