Home > Maintenance & Modifications > Not another tow bar question...
sonnyjim
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
Right guys apologies, I have done a search and there is lots of info, however...im still slightly confused.
If I purchase a 2006 RRS S/C without the towbar and electrics, am I right in thinking that all I need to do is to fit the electrics (Genuine 2 x 7 pin) and everything will work, no re-programming is needed?
I did (just for a laugh) spoke LR this morning and asked for a quote, they wanted £840 for fitting it, including the tow ball....however the tow ball does cost over £430.
Is the 55 plate car much different from the 06/56 model in regards to fitting the electrics??
Thanks guys
Post #387847 Thu Jul 04 2013 10:38pm
You can buy a Thule (OEM quality) tow bar for half that LR price... 2012 SDV6 - it's missing a couple of cylinders
Post #387848 Thu Jul 04 2013 10:52pm
sonnyjim
Iv seen them on ebay oem ones for 160.
Its more the electrics im worried about.
Post #387849 Thu Jul 04 2013 11:11pm
MAW
Electrics are a DIY fit in under an hour - kit used to be around £80 OEM - £40 ish on ebay if lucky.
I have a towbar for sale - looking for £150
I have fitted electrics to a 55 plate a 58 plate and current 61 no prob at all (the 61 plate had the main loom in place IIRC).
Software mod is to turn fogs off the rear when towing to eliminate glare in the rear view if you were towing a tin tent.
Post #387854 Fri Jul 05 2013 6:59am
sonnyjim
Thanks MAW, that has cleared it up. Will keep that in mind regarding the tow ball.
Post #387943 Fri Jul 05 2013 7:46pm
sonnyjim
Just a little update to this thread, I picked up the tow hook and tow electrics of ebay and fitted them myself, took me about an hour. Instructions was ok, think it showed a Disco or something else as the variant model as took a little deciphering, however did not take long to work out.
Post #390835 Sat Aug 03 2013 9:45pm
