![]() | Home > General > suspension problem |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9069 ![]() ![]() ![]() |
Could be the relay - did they change it when they changed the compressor? They are known to get a little "tired" and cause compressor symptoms.
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 ![]() ![]() ![]() |
Hi
Considering that the car is handling like a suet pudding and the suspension is playing up, I recommend you take it to someone who knows what they are doing! |
Sounds like you have a leak and thats why the compressor is running, if they have changed it to the new type they would have to have changed the pipe work get this checked as this could be the cause of your leak.
An overview of the system from the D3 manual (which is basically the same on the RRS) http://www.rrsport.co.uk/gallery/albums/us...tion~0.pdf 2012 SDV6 - it's missing a couple of cylinders
