![]() | Home > Faults & Fixes > Alternator burnt out, how long did yours last. |
Timo in Leicester Member Since: 08 Dec 2011 Location: Leicester Posts: 17 ![]() ![]() ![]() |
Mine gave up at 60,000 miles. 2007 v6. A slow death, the non charging light came on when on the motorway, but got home and local independent swapped it. |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Car came back yesterday, all running smoothly. Question do the alternators fail more often on Range Rovers than any other car on the road? |
Mike767 Member Since: 31 Aug 2012 Location: Cheshire Posts: 19 ![]() ![]() ![]() |
My 2006 Disco 3 went at 90K. Electrical burning smell and battery light came on. I believe the issue is the diode pack which is part of the alternator. Easy enough to replace but you need the viscous fan spanners to get the fan off. |
23,000 miles on TDV8 - my dealer reckoned a non-standard battery (100 a/hr) presumably fitted by the previous owner's dealership, was not compatible with the charge controller and led to the alternator's early demise.
Rover T Member Since: 11 Oct 2012 Location: West Posts: 11 ![]() ![]() ![]() |
My altenator packed up on Monday at 54K miles. Battery light came on and stayed on in the dash. New one fitted along with a belt and when they were at it ,the belt tensioner bearing was bad ,it replaced also.....
MEV6 Member Since: 02 Nov 2012 Location: Wilts Posts: 50 ![]() ![]() ![]() |
Whats the standard rough cost of an alternator replacement on the RRS? My last car an Audi RS6 went pop at 60k which you could almost bet your wife on that. £900 to fix |
Bandit8 Member Since: 20 Oct 2012 Location: Essex Posts: 99 ![]() ![]() ![]() |
I had to get mine changed at 39000 miles and the cost form a none LR dealer was £365.00 all in. This was a replacement LR part and not a new one. I was told that a new LR one would cost around the £600 mark. |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
has any of these problems acured a wineing sound from engine when revveing u ?? 2007 COOLRRS |
Whiny sound with revving is usually the air con clutch. Or could be one if the bearings for the aux belt usually the tensioner.
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 286 ![]() ![]() |
Bit late for you chaps, but for the next to pick up on this thread.....
I can fit these as well if needed. |
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 ![]() ![]() ![]() |
Just had mine replaced, it was overcharging the battery. £250 plus fitting. 2014 Nara Bronze SDV6
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
86.000 KMS or some 50.000 Miles.
embar76 Member Since: 05 Mar 2012 Location: Poland Posts: 7 ![]() ![]() ![]() |
My alternator burned at 118 000km. TDV8/2007 |
