![]() | Home > Technical > 2010 hesitation on cruise/ momentary loss of power |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
Could just be the EGR system...on part throttle it allows exhaust gas in to the engine which means that on throttle application it takes a moment for the system to breath clean air and then develop full power. 2012 SDV6 - it's missing a couple of cylinders
Are you sure it is a momentary loss of power and not a momentary loss of drive? When it occurs what does the tacho do? Any messages on the dash? Have you had the fault codes scanned? 2008 MY Java Black TDV8 HSE
robert997 Member Since: 20 May 2009 Location: West Midlands Posts: 5 ![]() ![]() ![]() |
Thanks because its so irregular I haven't seen the rev counter dip or anything. It's literally less than a second but enough for everyone to feel it.
abcsworld Member Since: 08 Jan 2012 Location: France and UK Posts: 12 ![]() ![]() ![]() |
On my 2012 sdv6 hse I had a 'hole' in acceleration arund 130km/h...came out to be accerator potentiometer. Since stealer changed it, problem is gone. They had a note from Land Rover on this issue. The symptom was the car would hesitate and hick up. At higher speed problem would be gone, at lower speed problem would be gone. |
Robert,
In 2010 LR issued a bulletin concerning "3.0 TDV6 Stumble/Misfire (130kmh/80mph)". Apparently there were reports of a slight stumble/misfire at vehicle speeds of 130kph (80mph)....
