![]() | Home > Maintenance & Modifications > TDV8 Brembo Brake Pads & Discs |
Jacking:
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 ![]() ![]() ![]() |
Thanks for the Jacking link Paddi.
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 286 ![]() ![]() |
Sorry bit slow off the mark there chaps
I have done a search and seen many people recommend replacing the discs with original LR parts and then use aftermarket pads.
Brembo are the OE Disc supplier to LR Paul Redding
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4355 ![]() ![]() ![]() |
Yellowstuff pads |
OK, I bought the Brembo pads (from Steve at Advanced Factors, a sponsor here) and an original LR brake sensor from my local dealer Hadley Green. Got myself some copper grease etc and was all ready to change the brake pads.
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
I think you need to put the car in low mode and lock it (I.e hold button pressed until locked) then jack up.
You can jack one wheel up at a time under the wishbone bpwith no problem. I still use an axle stand just to be secure. |
Anyone know what the correct torque is for the Brembo caliper bolts please? Changing my front discs and pads this weekend and have done one side today but can't find the torque setting so just did them very tight about most I can get is 150 Nm but the TdV6 fronts according to Bodsy brake bible is a muscle popping 275Nm which seems a bit high for an aluminium caliper? 2008 MY Java Black TDV8 HSE
scott1963 Member Since: 27 Jul 2014 Location: scotland Posts: 18 ![]() ![]() ![]() |
hi dont do what i done bought aftermarket discs and pads to cure a steering wheel shimmy i went through three sets of discs and pads before i found the steering wheel shimmy when applying the brake i went and bought genuine brembo discs and the pads from dealer problem solved when i looked at the brembo pad there is a differance the face of them are straight aftermarket ones are angled at each end witch dosnt help when applying the brake as it dosnt cover the full disk the brembo pad covers the whole disc.anyway the brembo calliper has harmonic weights on them that cuts out the brake sqweel so i found out the hard way £££££££ when all i had to do is put the correct pads in dont try and cheep skate these 4x4 it will bite you in the bum |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
interesting, I have changed front pads to Mintex with a bit cut off either edge, and they work fine, done nearly 1000 miles now 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
I think it unlikely that your problem was caused by the chamfer on the pads; this quite normal (if not for the Brembo type ones) and found on most styles of pad to reduce noise and vibration. The issue will have been caused by the poor quality pad material itself. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
