Home > Technical > Alternator on 2006 RRS 2.7 diesel
tizifred
Hey Guys
Does anyone have any idear how to change the alterator on the above car?
I must be thick or something, but I can't see how to get at it
CHeers
Fred
Post #386653 Sat Jun 22 2013 1:51pm
ELD70
Go to the D3 forum, sure there is a guide there...
Post #386654 Sat Jun 22 2013 1:58pm
tizifred
Thanks
Post #386655 Sat Jun 22 2013 2:02pm
flack
Remove the positive battery cable first
You then need to remove the air pipe from above the radiator, then the fan cover. Next remove the viscous fan with 33mm spanner and fan locking tool then you can see the alternator at the front lower left as you look at the car. 3 bolts and a cable, then the plug at the back.
Flack Thumbs Up
Post #386667 Sat Jun 22 2013 5:01pm
tizifred
Thanks guys
The alternator is now off. For those that don't know, you have to at least loosen the dynamic response pump as well
Post #386692 Sat Jun 22 2013 9:58pm
Disco_Mikey
An alternator on an RRS with the DR system is a right pain in the Censored
Much easier on a non-DR TDV6 Thumbs Up
Post #386695 Sat Jun 22 2013 10:34pm
