Home > In Car Electronics > Music over Bluetooth
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Morning all,
I've been trying to get music over BT for my 2006 Sport however everything I've tried doesn't provide a workable solution when combined with the OEM BT for the phone.
Currently I can pair my Samsung S3/ Note 8 with both the Land Rover phone BT and the Unisound Music BT unit I have installed and play music over the BT. However, when I then make or receive a call I get large amounts of interference Sad , I presume from the UNisound device.
The Unisound device is wired in via an ignition feed for power and into the aux in for sound.
A way around this is to pair 2 devices, 1 for music & navigation and 1 for phone, but this defeats the objective in that I want to use 1 device for music, phone, navigation etc. This would ultimately be a Samsung Note 8 mounted in front of the OEM Nav Screen so that I can access all my contacts, music and navigation etc easily from one device.
So the question is would it be possible to use the BT module from a 2010+ Sport, which I believe has music over BT in lieu of the LR4 module I currently have so that both music and phone are streamed to the Sport via 1 OEM module?? Anybody have any ideas?
Any other advice would be great help also Thumbs Up
Thanks in advance.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #385651 Mon Jun 17 2013 5:53am
muddywheels
Milk Float Man
Bodsy is the best person to answer this I think - you could drop him a pm Thumbs Up
I have a 2010 and it can not stream music by bt but I use an iPod or usb memory stick and find that works perfectly Cool Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #385656 Mon Jun 17 2013 8:25am
Bodsy
Site Sponsor
A 2010 module would just give you enhanced telephone contacts, signal strength and phone provider, nothing changes on streaming music. I.e. You can't do it, sorry. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #385660 Mon Jun 17 2013 9:09am
Guyzer73
Thanks for the responses Gents,
Would a later module be able to be used if it offers A2DP and HFP protocols/ profiles for example an "Ewok" module?? I thought the 2010 offered A2DP, obviously not Sad or is that only offered in the new 2014 RRS?
Thanks agaon for the help Thumbs Up
Post #385665 Mon Jun 17 2013 9:29am
jack.bauer
How you getting on with this mate ? 07 TDV8 + BAS map
Post #394993 Sat Sep 14 2013 12:19pm
