| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Sport 2.7tdv6 2007 injector rate |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Was this at idle speed as I think it is did you try to increase the rpm to 15,000 or higher and then check the readings...
|  Thu Jun 13 2013 9:23pm |
| sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91      | Hi yes this was at idle speed ! Should I have revved it up too ? | ||
|  Fri Jun 14 2013 7:29am |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Yes you might get a more accurate and even reading then..
|  Fri Jun 14 2013 7:35am |
| sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91      | Do you know wat readings I should be looking for ? Wat levels it should be ? Cheers | ||
|  Fri Jun 14 2013 6:58pm |
| Posting Rules
