Home > Technical > Name this part and its purpose - please ?
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
Have a knocking noise coming from rear of RRS S/C so got it up on ramps to check for worn bushes etc. All OK, so it seems. Noticed these two great big lumps of steel either side of towbar behind rear bumper, which swing and hit the exhaust tail pipe on one side and the bumper plastic on the other, causing these noises. BUT, I can't for the life of me work out what they are and what they do !
  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #385028 Sun Jun 09 2013 2:15pm
I beleive they are the harmonic dampeners, there to reduce noise though they shouldnt be banging things
Post #385035 Sun Jun 09 2013 2:49pm
B3EEE
no, think those are on the axle, or similar, maybe on/near crankshaft ?  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385036 Sun Jun 09 2013 2:54pm
B3EEE
OK found this
They are pendulum weights and are there just to reduce acoustic resonance (they counteract resonate frequency vibrations coming off the frame of the truck.) Mass dampers seem to be the term.
but they bang into things ! and make noises !!  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385039 Sun Jun 09 2013 3:05pm
B3EEE
can someone check their 'dangly' bits and tell me if they too hit the bumper or exhaust tips ? maybe the mounts on mine are worn and are dangling/swaying too much ? Lol  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385045 Sun Jun 09 2013 3:42pm
msramsden
I was just about to ask the very same question, I noticed them earlier when giving the under carriage (the cars not mine) a clean.
Mine are loose and swing about a lot (again referring to the cars dangly bits not mine)
I'm getting out of here before my dangly bits get me in trouble (again) TDV6 HSE - Rimini Red
300tdi Discovery Commercial
Post #385046 Sun Jun 09 2013 4:13pm
B3EEE
Yeah, I've found a fair bit of info about them, and the reasoning behind it, but don't see why they should move so much and hit surrounding objects. I bet many bushes etc have been replaced due to these ! Lol  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385047 Sun Jun 09 2013 4:22pm
msramsden
I suppose a solution could be to stick some dense sponge/foam on them at the points they make contact with the surrounding areas. Might reduce the noise they make when they clatter the surrounding metal. TDV6 HSE - Rimini Red
Post #385048 Sun Jun 09 2013 4:41pm
B3EEE
well, to test that these were the cause of the knocking, I stuffed a few old rags around them, and the noise all but went, but the one is too close to the exhaust tip to keep something stuffed in there for too long - unless I wanted flames coming out of my exhaust !  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385050 Sun Jun 09 2013 5:02pm
Are the exhaust tips the original fit items or aftermarket replacements? 2012 SDV6 - it's missing a couple of cylinders
Post #385051 Sun Jun 09 2013 5:30pm
drdelrrs
They are there because it was a cheap fix for LR as they couldn't be bothered to design out the harmonics so the easiest way was to hang some heavy weights in various locations to 'tune' out the unwanted sympathetic vibrations. They obviously contribute to why the RRS weighs so much as you're carrying around several kilos of deadweight.
If they are swinging about relatively loosely its because the rubber bush(s) has deteriorated.
I've a feeling I've seen a note suggesting that if owners complain that dealers can remove them - but t'was some time ago so I could be wrong/out-of-date.
Post #385052 Sun Jun 09 2013 5:32pm
B3EEE
original
I'll see if new rubber mounts can be bought for them, but a quick look tells me that half the car has to come apart just to get at them ! Is there flame proof rubber out there to pack around them ? Lol  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385054 Sun Jun 09 2013 5:54pm
Bradders
Just had a peep underneath and sure enough mine swing like the 60s!!
I wonder if that explains the rumble I can hear going over bumpy roads ?? I assumed it was bushes but they seem ok. Mines in for 75k service in a couple of weeks I'll see what they have to say about them then.
Cheers for posting B3EEE - I never knew they were there Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #385055 Sun Jun 09 2013 5:59pm
B3EEE
and think how many have changed bushes etc only to still have the noise ?
Try swinging them, do they hit anything. Mine hits the bumper, but I think I have an aftermarket HST bumper so may be nearer the dangly bits !
so if you hear a noise that you think is something banging around in the boot - you got "swinging danglies" at your rear !
.  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #385057 Sun Jun 09 2013 6:04pm
Bradders
Yep mine swing happily - the nearside seems to bang the underside of the car and the offside catches the rear bumper and the underside of the car. Rolling with laughter FF 4.4 V8 Soooo looking forward to this bad boy
Post #385058 Sun Jun 09 2013 6:16pm
