| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Fluid Change. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Reidy,
|  Thu Jun 06 2013 10:40am |
| reid7774 Member Since: 12 Apr 2012 Location: Thurso Posts: 73      | Paddi once again your back with all your wisdom  | ||
|  Fri Jun 07 2013 3:24am |
| Posting Rules
 , a post i put up a few weeks ago had a reply from PADDI and a few others, thanks again,
 , a post i put up a few weeks ago had a reply from PADDI and a few others, thanks again,  i was advised to change all the fluids, diffs,transmission including transfer box and engine oil. Could you guys tell me what oil is required for each and how much and if anything else is required, such as sump plugs etc as i am away at work at momemt and would like to order the oils etc for when i get home. Also are the oil changes straight forward ( can be done in a normal garage ) or do i need any specialised tools etc. Also any how to pages i could look at and follow, i seen the one on how to change oil on tdv6 disco, is this same as v8..Thanks again guys....Best forum i have seen.
