Home > Technical > Low coolant
RRSRP
2007 Range Rover Sport TDV8 HSE Stornoway Grey
Low coolant
Hello all only been owner since December but could anyone tell me how often I should be filling my coolant level as I seem to be doing it every 400 miles or so but no sign of a leak. Also can the coolant be diluted. Thanks Question
Post #384336 Thu May 30 2013 12:49pm
It shouldn't need topping up really. And no, you shouldn't really dilute it.
Mine was losing coolant last year - turned out to be a leak in a thermostat housing I believe. Otherwise the EGRs are common locations for leaks. 2012 SDV6 - it's missing a couple of cylinders
Post #384341 Thu May 30 2013 1:29pm
PEACHY
Funny enough topped mine up again this morning. I don't do it that often but still interested in what could be the cause ? all systems have been checked & double checked & the coolant is definitely lower Shocked 16MY Estoril Blue SVR.............
Post #384342 Thu May 30 2013 1:30pm
BigCat8810
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
I had a similar issue on a 2005 4.4HSE. The local specialist claimed it was a hose deep in the bowls of the engine, cost me £500 to prove it was actually a simple and known fault with the header tank, which had failed and was only £60 to replace!
One thing I remember was being able to smell coolant under the hood when she was running hot, so it might be worth checking this out on yours.
Best of luck. --------------------------------------------------------
RRS TDV8 Black/Black (Gone)
RRS TDV8 Stornaway (Gone)
RR Vogue TDV8 (Gone)
RRS 4.4V8 (Gone)
Defender 110 300tdi (Stolen, much missed)
RR Vogue V8 P38 (Gone)
LR 90 TD (Gone)
Post #384401 Fri May 31 2013 8:47am
