![]() | Home > Technical > Special systems off and no power 2.7 tdv6 |
| Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104
Mine did this and turned out to be a sticky egr valve. Best to get it on the old diagnostic machine tell you straight away if it is the egr. |
| chuckmiester Member Since: 01 Jan 2013 Location: barnsley Posts: 8
Egr valves are blanked of. |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Mine's currenlty doing the same.
Could be a pipe round the turbo with a slight split. As from what you described happens when the engine is under heavy demand. Need fault codee ideally to point you in the right area |
car going to Doug Dransfield indie today to have codes read. Hope I can get it sorted, taking caravan to silverstone to British gp at end of June. |
Got car back from Doug Dransfield and the fault was "turbo over boost". They said because the car has never towed before the variable vain turbo might not be fully working because of a carbon build up. The car is running fine with no caravan on the back and as the caravan is only borrowed I think I'll let the problem develop. |
I'm thinking the same.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
What we need is for someone brave to try this turbo cleaner on their V8: http://innotecturboclean.co.uk/
| All times are GMT |
