Home > Technical > GPS problem with voice commands
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I have a 2009 sport and having a problem with giving voice commands. I am getting NO VOICE DETECTED when I try to give a command. It has been suggested it might be the mike that is at fault?!? Can anyone tell me where and how to get to the mike. Andrew Andrew Kennedy
Post #383868 Thu May 23 2013 8:38am
Bodsy
Site Sponsor
The mike is in the front overhead light cluster.
Pull it down from the front and the whole unit clips out.
Its likely to be a broken wire between that connection and the back of the radio, so just splice two new wires in. Easy enough to run up the a pillar and through the headlining. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #383870 Thu May 23 2013 8:44am
