![]() | Home > General > Wheel Alignment |
Check out this website and see what garages are near you, preferably with the Hunter equipment |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
lo all,
Brake pipe is less than £7 from land rover. That's if it's the one on top arms. If its one over axle it's major surgery. Bushes are either LR or Polybush 2x TDV6. SE and HSE. Both returned to sender with issues👀
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
My most local dealer through that website lists 4x4s as 'from £90' ![]() 2007 Exige S British GT SE Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating ![]() |
That's bad, I got mine for £55 from memory. Just goes to show there are always people out there trying to make more money out of others. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Make sure that the place you're using has the correct link to be able to put the suspension in to fine tolerance mode. My local place doesn't because they've only had the pro-align kit for a short time and hadn't had any interest from LR drivers. As I have the IIDTool I could set my own to FT mode. 2012 SDV6 - it's missing a couple of cylinders
