Home > General > Supercharged Fault Advice - Supercharger?
PauloAmore
Scotland
Guys
Driving my SC this evening and noticed;
- reduce engine performance (no LED error)
- increase in engine noise
- no supercharger whine.
Thoughts?
All advice appreciated. With thanks in advance
Paul 2022 P440e AB
Post #382431 Tue May 07 2013 8:29pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Check if supercharger belt has not snapped.
Post #382515 Wed May 08 2013 5:06pm
PauloAmore
Scotland
Feeding back lest if helps another user;
Looks like an engine temp sensor fault.
- which causes the viscous fan to run all the time (creating the noise). 2022 P440e AB
Post #382874 Sun May 12 2013 8:50pm
shepp
Where you driving it hard? If so could be the sc coolant pump wired backwards. Very common on sc 's . Changed mine and correctly wired. There is a tsb for it.
Post #382883 Sun May 12 2013 9:38pm
PauloAmore
Scotland
Well, for sake of other Owners...
Turned out it was the control cable connection to the viscous fan... needed reterminated and soldered on.
- so the engine fan ran all the time (speed pro rated for engine load)..
And sounded so loud one couldn't hear the supercharger. 2022 P440e AB
Post #383939 Thu May 23 2013 9:36pm
