Home > General > Someone please read this and please help !!!
Ross_wida
2006 Range Rover Sport TDV6 HSE Siberian Silver
I have a 2006 rrs hse 3 days ago i got a problem which was these faults
1) HDC Fault
2) Parking Brake Fault
3) Parking Brake amber light illuminated
3) No special Programs
4) Speedometer does not work/miles do not accumulate on display
5) DSC and ETC amber light
6) Check Engine amber light
7) Suspension amber light
Cool Suspension is in access height
9) ABS light is illuminated
I was told 100 % it was wheel speed sensor so i had it plugged on a diagnostics machine which confermed right rear wheel speed circuit so i changed the wheel speed sensor and still had the same problem so i had another look and discoverd a broken wire just behind the plug where the sensor plugs into so i had the wire repaired and thought i was in luck as now when i start my car there are no faults what so ever untill you drive the car 6-8 metres then all of these codes come back ! then you turn the car off and on then there gone again untill you start driving !!!! i really dont no where to go from here the diagnostics still states there in a fault on right rear wheel speed sensor circuit !!!! Can someone please help me i really dont no where to go from here ??????????????????
Post #381213 Mon Apr 22 2013 9:03pm
Bodsy
Site Sponsor
I would check the wiring again, it may be broken in more than one place.
I wouldnt worry too much about all the erros etc as one simple issue can cause what seems to be armageddon on the instrument panel. if its saying that wheel speed sensor faulty, and youve replaced it, then wiring is usually the culprit. Although if DiscoMikey sees this, he may be able to pinpoint potential wiring issues more accurtaelyi from any hes had in. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #381222 Mon Apr 22 2013 10:09pm
Disco_Mikey
The wiring for the speed sensors run down the N/S/F wheel arch on 05/06MY's such as yours. They are notorious for broken wires in this area, and would be my next area to investigate Thumbs Up
Post #381232 Mon Apr 22 2013 11:04pm
