![]() | Home > General > Headlight washer jets not working |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
There are two motor pumps, one does washers one does lights. To access them the bumper will need to come off. I suspect it's burnt out after weeks of frost and snow froze it. Not being a sparky, am not sure if there is a seperate fuse but worth checking. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Washers will not work if they have been used within the previous 10 minutes.
| UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149
Check that you have plenty of water in your bottle.
| oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148
........this is such a great fourm!
Learn something everyday! Knew that light washer only triggers every third time but not come across the ten minute rule |
Hey guys - it is amazing what you find if you read the Handbook |
Last time I looked, I was male so don't do manuals |
Smartybloodydownunderpants! |
| Coxlong Member Since: 01 Aug 2012 Location: UK Posts: 21 |
Still can't get them to work so the only thing I can think is the burnt out motor |
