![]() | Home > Maintenance & Modifications > Air Suspension Fuse Blowing |
Is it constantly running (except when the fuse has blown of course) check the relay as they are known to stick when they are reaching end of their life. Bodsys Brake Bible
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Thanks Bodsy new relay fitted as per your previous suggestions, ran ok for nearly 2 weeks and then blew again, I have a new AMK compressor ready to go on. Can the motor on the compressor cause the fuse to blow? Thanks... |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4475 ![]() ![]() ![]() |
Yes, a dead/dying compressor can also cause the fuse to blow |
Many thanks all, just checked the fuse and it is OK, so the system must have locked out for some reason? Need to get it on a diagnostics system. It is now working normally since taking the fuse out, but for how long ? |
Autobiography Conversion Member Since: 15 May 2013 Location: London Posts: 12 ![]() ![]() ![]() |
Could be water within the compressor itself. If so then the dryers gone and needs to be replaced. To check just remove the compressor/pump and check for water inside if it's got some water in it then the dryers at fault and needs to be changed. Hopefully that should stop the fuse going. |
Thanks, ended up replacing the compressor for a new AMK and upgraded the software all working well now, brilliant service from Frogs Island http://www.frogsisland4x4.com/ |
Nice to hear that got sorted. I just had mine done last week, my suspension was taking forever to raise and then just ended up in load mode. Yellow suspension failure light came on also. Got the part from Lookers in Park Royal and had it fitted - works fine now. |
