| RRSPORT.CO.UK | ||
|  | Home > General > Brake Discs & Pads |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Depends on lots of things. Is it first set of pads to be reaced, is there a big ridge or rust on the disc? If they are Brembos, get oe discs and pads. If its rears then decent quality copy parts are plenty good enough. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Fri Mar 22 2013 8:51pm |
| Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259      | The pads would have been done in the past by the previous owner.
|  Sat Mar 23 2013 7:59pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | My advice would be to fit genuine pads to Brembos. I tried spurious pads and the car really didn't stop that well, so went to dealers and bought genuine. If the discs are fine don't change them. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sat Mar 23 2013 8:45pm |
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280      |
 I agree. For Brembos use genuine pads and discs TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten | ||
|  Sun Mar 24 2013 12:44am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I understand that the pads used by LR are actually made by Ferrodo irrespective of the brake system used. 2012 SDV6 - it's missing a couple of cylinders
|  Sun Mar 24 2013 8:35am |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441      | The front pads are labelled up as made by brembo, it says brembo on the back of the pads.
|  Sun Mar 24 2013 9:36am |
|  Sun Mar 24 2013 9:58am |
|  Sun Mar 24 2013 10:07am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Just in case you didn't get it the first time  | ||
|  Sun Mar 24 2013 10:31am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | You can buy uprated EBC brake pads for half that price.
|  Sun Mar 24 2013 12:49pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Have you tried them Mikey? Interested to know how they perform when cold. Only ever used green stuff which are great when warm but don't stop you at all when cold.   | ||
|  Sun Mar 24 2013 12:59pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | I used Redstuff, and thought they were amazing. Almost no brake dust from them, and initial bite was great, and only got better as they got warmer. Just make sure they are the ceramic compound   | ||
|  Sun Mar 24 2013 1:42pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | If and when the beast returns, I might give that a go, my wheels go black within a day of being washed so anything that reduces this is good  | ||
|  Sun Mar 24 2013 2:40pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | I certainly had no issues with brake dust. Were even cleaner than using OEM pads   | ||
|  Sun Mar 24 2013 3:49pm |
| Posting Rules
