![]() | Home > Technical > The correct ride height for the RRS |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The system is only accurate to about 10mm when running in normal tolerance so +/-12mm seems reasonable (assuming they mean "within 12mm" rather than "within 24mm" (which is what +/-12mm actually means)) 2012 SDV6 - it's missing a couple of cylinders
Hello
| quantumjohn Member Since: 17 Mar 2013 Location: NW Kent Posts: 53
That seems like a large tolerance still. If it was down one side and up the other by 12mm each that would be visibly noticeable.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
12mm is nothing I would suggest Mike
| All times are GMT |
